Can`t get linked module to Responsivizer module (1 viewing)
TOPIC: Can`t get linked module to Responsivizer module
#743
Bulrose Ltd.
Can`t get linked module to Responsivizer module Karma: 0
I`m trying to add additional module into the template of Responsivizer, but with no success. No the mobile version is working, but only with 2-3 modules, which are default and meet the default settings.
I`m trying to add module position contactus into responsivizer_copyright from Control Panel, but when I try to save the settings and get error: Error saving positions associations, COM_RESPONSIVIZER_SAVEFILE_ERROR
So.. the result is that I can`t get working my website module, which is costum into that position. Maybe can`t save the settings. Where is the problem? Please help me.
#744
Re:Can`t get linked module to Responsivizer module Karma: 84
if you experiment issue when saving positions associations try to check the chmod permissions for the file used to store data. The error is related to a file write error.
the file used is this:
joomlapth/templates/responsivizer/framework/modules/dbpositions.json
As a side note if you need to assign existing modules to a responsivizer position, you can also use the Modules Manager and the 'Make mobile' button to migrate modules from desktop to mobile template.
